TominTampa's avatar
TominTampa
Hypothetical DC electrical Question
Hello All,
I have a hypothetical question concerning DC electrical power in a diesel pusher RV. Our rig is a 96 Dynasty with a mechanical Cummins C8.3 (96 was supposedly the last year for the mechanical C8.3, then they went to computer controlled). Now what if the engines alternator failed. First you get a warning on your dash, most likely the "ALT" light would come on, or you "VOLT" light, then you would pull over and try to figure out what's causing the problem. So, let's say that you conclude that the alternator has failed, and here's where the hypothetical part comes in. When I run the Onan generator AC is supplied for the coaches AC needs, and some of that AC is converted into DC and fed into the DC system for charging the battery, running the lights, etc. So, would the Onan generator supply the DC voltage I needed to limp home until I could get the engine alternator repaired? The engines DC needs are relatively small as opposed to a gas engine, and I figured with daytime driving only it might actually work. Any inputs are much appreciated. - Tom
