PsnRebel
Oct 28, 2023Explorer
Campforever wrote:
Fill black tank from inside the camper i.e., use a hose and stick in in the toilet close the toilet on the hose and start filling. On mine, with a 40 gallon tank I run it 11 minutes then drain.
I do this for about 4 to five cycles or until the water is running clear.
When filling from the toilet you should clear out the shelf.
Truely not a aftermarket design to benefit the buyer.
That is why we adapt, improvise, apply.....
Pretty much the exact procedure i do once the pyramid is formed and i have the “luxury” of being hooked up to a city water connection, or when we have to find a dump station somewhere along our travel route (usually bt CA or GA). Luckily Love’s truck stops typically have a dump to access.
I probably use 150-200 gallons of water to dump the tank properly. Similar to you it’s about 9-11 minutes between pulling the dump valve. So 4 x 10 minutes is an easy 40 minutes of baby sitting the hose and tank alone.
I was hoping my bathroom sink in the toilet “closet” was hooked to the black tank because we rarely use that sink. So id use it more if it was, hoping that would help, but its not.
