Artum_Snowbird
May 19, 2016Explorer
I would first be sure to have each one numbered, then do an ohm check between the center and the shield to see which ones might be connected at the other end, and which ones are not.
From there, go to your known devices and disconnect or jumper, one at a time, noting any changes at the other end.
Eventually, you will have it all figured out.
