WyoTraveler
May 19, 2016Explorer
I label any coax that is still connected. Build a connector with a known value of resistance. connect it to one end of the cables. Check through the other end of cables with an ohm meter. When you find bot ends label it and move your resistance connector another cable and repat the process. I use a resisto on one end because you want to rule out shorts or cables that may still be connected to something else.
