Bill_Satellite
May 19, 2016Explorer II
If you happen to be near Houston, TX let me know and I can trace it all down for you.
It's pretty obvious that there used to be a Winegard video distribution box (what some call a BOMB or box of many buttons). That means that if you have 2 TV's 2 of those coax cables are a direct run to the TV coax input. Using the distribution box you could sent OTA TV, Cable, VCR (remember those?), satellite and usually an AUX option. With all of the cables disconnected and not labeled you just need to take a bit of time to trace each on down. For coax you just need a multi-meter. Push some tin foil into one of the coax ends in your hands which will cause a short as far as the multi-meter is concerned. Now you can go to all the exterior coax connections (roof, wet bay, storage compartment) and test each coax connection until you find a short. To confirm you have the right cable you can pull the alum. foil off and test the coax again. Now, it should not show a short. Work your way through all the cables and you will know exactly what goes where.
Now, since technology has changed so much recently, just getting things connected the way the coach was built might not solve your problems. ONLY HD OTA TV and possibly HD cable can be sent via those coax cables. If you want HD satellite TV or HD DVD/BluRay connections you are going to need to run new cables.
