liborko
May 28, 2013Explorer
I think ClassAgeek is correct. The purpose of the sway bar is to pull left side of the coach down by same amount if right side is being pulled down by sway. If you move second hole even closser to the axle, or all the way to axle, you will have zero suspension travel because there will be solid connection between the axle and the frame rail. So using inner hole in fact just reduces suspension travel and increases stress on sway bar bushings.
38,782 PostsLatest Activity: Sep 02, 2026
