- wolfe10ExplorerManabloc valves can also become mineral-coated so that they will not operate. Have seen that on several RV's and boats with the system.
When it works, it is a great idea-- one can shutoff single fixtures, leaving the rest of the system operational. - eheadingExplorerWe had a manabloc system in a Monaco Windsor years ago. It worked okay. The only disadvantage I saw to it is that because of bringing all the water lines to a central position, the lines to any given fixture are longer than when the standard system is used. This meant that we had to run the water a lot longer if we wanted hot water. Since we normally run off the water in our tank, this was a monor disadvantage to us. Other than that, the system worked fine.
Ed Headington - JetAonlyExplorerIt's spelled manabloc.
- TinstarExplorerThe reason I asked is the coach I just bought says it has the Manobloc system. I tried to Google it but I didn't find the information up above.
Thanks for the info. - RayChezExplorerMy coach has the manobloc system. If you have a water leak on a water line hot or cold you can shut it off right at the manifold. Never have used it, but it is there.
- DSDP_DonExplorerThe manabloc system was used on high end coaches to isolate various plumbing segments in the coach. If you broke a water line in the bathroom, you could turn off that line without losing use of the rest of the coach. I'm sure it also aided in winterizing. I haven't seen them in new coaches for a long time, maybe a Newell or Prevost level will still have them.
- FCExplorerOur Georgetown motorhome has this system. They only installed it one year I believe.
- coolmom42Explorer IIDon't know about the ones for motor homes but the versions for homes work really well. My son-in-law just overhauled the plumbing in their older home, and replaced it with a manifold system plus PEX. Each fixture can be shut off separately and the pressure is very uniform. No more scalding showers when someone flushes.
- midnightsadieExplorer III think these are used in floor heating systems ,
38,778 PostsLatest Activity: Jun 05, 2026
