DFord wrote:
I drove a big Penske truck from St Louis to Naples a couple of years ago. It had 22.5 inch tires and must have had beads to balance the tires. Every time I came to a stop and started off again, the tires would be out of balance. I'd have to drive a couple of miles for them to smooth out again. I'm not a fan of putting a bunch of beads, powder or dust inside tires. I'll always go with a good wheel balance. I'd rather pay for balancing my tires than have them put crystals inside them for free.
I have noticed that if i keep the truck on cruise control and dont hit any bumps sometimes the shake will seem to fade.
Ive been watching tons of youtube videos about issues with the bead balancing and im 99% sure the beads are my issue. The can clump up on any amount of moisture, and i can see on the tires where the techs used lube to mount them! Theres tons of it! If you ask me, that lube must have made its way to the inside of the tire bead and mixed with the beads, causing them to clump.
So the question now is, can i have these tires road force balanced with the beads still in the tire? Or does the tire have to come off and get cleaned out? Really amazing help from everyone here! I needed this
