Cmccain13's avatar
Cmccain13
I Need a checklist
Ok so I just bought a new RV (32ft coachmen leprechaun) class c and we got to stay the night at the dealership to test it out before we took it home. I will be traveling the USa for the next 2 years but wont start the journey for the next three weeks. I would like to know if there is a checklist for set up and break down for my rv. any help would be appreciated.
  • wow thank you very much everyone this is very helpful, I felt lost and fell much better about it now. I'm sure ill be back with many.... many more questions.
  • Well, there are some here on the forum, and all over the net to boot. They definitely come in handy for newbies and veterans alike. It becomes second nature after awhile, we have had TT's, 5ers, and Class A rigs and although there are many similarities, each have there subtle differences. Congrats on your new Class C, once you get a system for setting up/breaking down, you can enjoy all your rig offers to its fullest.
  • Empty and drain the lines of your fresh water system.
    Also connect to your municipal water supply or run the water pump for a hydro test. Common complaints are the loose connections that could flood the Inside of your RV.
  • DrewE's avatar
    DrewE
    Explorer III
    In terms of a checklist, you'll quickly enough develop your own (usually by means of experience in forgetting things). I use a system I think I read about here somewhere: I have a bag of clothespins with checklist items written on them, and start by clipping them to the sun visor and then unclipping them and returning them to the bag as I do the items before leaving (or decide they are inapplicable at the time).
    Here are all the pins I currently have, in no particular order; your checklist items will probably be a bit different:
    Vacuum
    Sweep (linoleum)
    Shake Rugs
    Oil (check engine oil level)
    Counters (free of stuff that might fall off)
    Water Hose
    Bedroom Blinds (raised or secured in clips so they don't rattle about)
    Trash
    Close Windows
    Bedroom Windows (I'm not sure why I have them separately...)
    Electric
    Sewer (disconnect if full hookup, dump if tanks are full and there's a dump station)
    Welcome Mat (don't leave behind)
    Water Fill
    Ceiling Vents
    Awning
    TV Antenna
    Compartments (outside storage compartments closed and latched)
    Clean Windshield
    Tire PSI
    Water Heater
    Water Pump (I generally travel with it off--not really necessary to do so)
    Count Noses
    Prayer
    (I don't have any slideouts to worry about in my motorhome.)
    For storage at home, it's only necessary to empty the water tank and drain the lines (and winterize!) if there will be freezing weather. Some would suggest it's a good idea if the motorhome will be sitting for quite some time so you don't have water sitting around and maybe having stuff grow in it, and I wouldn't argue against them.
    Turning off the propane is not necessary, though it's also not a problem. The only times it's necessary to shut off the propane at the tank are when refilling the tank--and the employees at the fill station should do it then--or when driving on certain bridges or tunnels where propane is permitted but must be turned off, such as the Chesapeake Bay Bridge/Tunnel. When turning the propane on or off, take care to fully close or open the valve; they may leak if left in a halfway open position.
    It is never necessary in general use to bleed/drain the propane lines.
    The 12V disconnect switch is of limited usefulness. If you have 120V power where you have the motorhome parked, plug it in and leave the 12V switch in the connected position so that the converter can keep the batteries charged up. If you don't have 120V power, it's better to disconnect the batteries (remove the ground lead from the negative terminal) as often there are a few items that are powered regardless of the disconnect switch setting like the propane alarm, radio memory, etc., and these can drain the batteries over the course of time. Batteries do self-discharge even when disconnected, but the rate at which this happens is quite dependent on the temperatures; in freezing weather, it's very slow indeed, and not a concern over several months if they are fully charged to begin with. In hot weather, a few weeks can lead to a significant amount of self-discharge. Even a fairly modest solar setup can be a big help here.
    Setting some mousetraps is a good idea when the motorhome is in storage. Keeping it free of food that would attract mice is also wise.
  • Regarding your questions above, I see a bunch of reading is needed. Yes, drain and sanitize the water system. Wet cell battery? Check the water levels and keep it fully charged. Don’t worry about propane freezing....about minus 44F.
  • Matt_Colie wrote:
    C McCain,
    First Thing... NEVER SKIP the complete walk around.
    If you get interrupted and are not sure, start it again.
    I have used this app: RV Checklist from Adventure Treks LLC. It is free on Play.Google.com. I don't know if it is available for IOS, and I know that there are others. This one is easily editted to fit your situation.
    Between DW and I we still always do a full check when we move. It is not so important when we stop because if something with a MH doesn't work, it is seldom critical.
    Matt
    hey thanks for the reply, i will definently DL the app. yeah i did the walkthrough and it was alot of information. So we are going to have the MH at the house for about three weeks, do i need to empty the water tank, drain the lines, and turn the 12v switch to the off position? also i shut off the propane but do i need to bleed the lines somehow? i appreciate all your help as i am very green and this is the first time in an RV pretty much other than when i was very young.
  • Lots of checklists on the Internet. Download and modify....meaning add things. Never leave without completing. If I find a major missed item I start over. Not a time waster but a money saver!
  • C McCain,
    Matt
