Emptypockets
Mar 20, 2014Explorer
learningacrossameric wrote:
Well a bit of an update, everyone has asked questions and I will try to answer them. First of all I am boondocking in the mechanics fenced in yard AND he let me plug in and use his wifi! I had all the filters replaced back in Feb and had the gas tank dropped and repaired last Sept so we are eliminating the filters. He pulled the small one up by the carb and it looked fine. He thinks it is the mechanic fuel pump. So our plan is to put in an electric fuel pump in under the chassis and go from there. I asked about vapor lock and he seemed to think it wasn't hot enough for it. (When I had her towed in yesterday morning, the temp dropped to around 30 deg that night and she still exhibited the same problems when I pulled her out to get hooked up to the tow truck) So when the fuel pump gets in today and we hook it up< I will update again.
Sounds like you found a qualified mechanic hope he gets you going soon.
38,766 PostsLatest Activity: Jan 10, 2026
