DSDP_Don
Feb 15, 2015Explorer
You talk about your roof horns and your snail horns and then about disconnecting the roof to run larger snail types. Are they honking together, or do you toggle between the two?
On my previous DP, I had only the air horns and they could be overkill in some situations. I added some snail horns and a separate button that was easy to reach so I had a choice.
I really like the looks and size of that that "Wolo Bad Boy", but would be curious about how it sounds. I looked at the reviews and there were no bad reviews, plus the price was reasonable.
If you decide to go a little cheaper, the standard horns on a Ford Crown Vic are very loud and can be had a wrecking yard. They would probably mount in the same position as what you have and use the same connectors.
