ItsyRV
Oct 25, 2018Explorer
Does your's not have a dinette or are you wanting one in place of the sofa?
Winnebago often will have parts that are compatible across many years and lines but with different parts numbers due to a cosmetic change. Everything from brackets to cutouts are the same, just with a door underneath instead of a draw and that means a different part number. You can check with your nearest Winnebago parts to see if they can provide a cross compatible listing or contact WinnebagoParts.comand see if they have a dinette. They can check your coach serial number to get all the parts used in your specific RV so they would also know what dimensions will work.
Do you have any RV salvage yards near you? With a compatibility list or a good set of measurements, you may find a salvage unit from a Winnebago or one from another Rv that will fit based on dimensions.
38,778 PostsLatest Activity: Jun 10, 2026
