GordonThree
May 23, 2016Explorer
Back of the napkin so to speak;
30 amps at 120vac is 3,600 watts... 3600 watts at 12v is 300 amps. You'll have no problem running a 100amp converter off your 30a electrical system.
Depending on efficiency you'll need 12-15 amps at 120vac.
3000 amp dead-short discharge on those bad boy batteries, make sure you use a CLASS T fuse, not a wimpy ANL or dc circuit breaker.
38,769 PostsLatest Activity: Apr 04, 2026
