lj2654 wrote:
I went out to the Motorhome to check the ac. Seemed hotter than the 83 degrees I keep it set on. Turned down the thermostat and it started as usual, after about 12 seconds the compressor tried to come on, loud noises and it shut back off to just the fan. Original Dometic 13500 unit from 2001.Its a 600315.321 model. The thermostat was replaced last year with an lcd single zone thermostat and a new control box.
How do I figure out what the heck I need?
It's worth a go, to change out the hard start capacitor and if that doesn't get it, save it for a spare for later.
Just put in the new one, wire for wire, or look at the drawing on the cover.
