Hi, i have a class A motorhome and the ice maker hose sprang a leak. how do you go about changing it out. I can't seem to trace it down or see where it runs to. the manuals do not show anything.
It would help if we knew what model reefer you have. Most have the water line running up the back of the reefer visible if you take the external panel off. You can use compression fittings to replace a section of it without changing the whole line.
