wildmanbaker's avatar
wildmanbaker
Ice maker problem
For the past 2 years, the DW has been complaining about the taste of the ice for our Dometic Sidewise refer. So we also had 4 plastic ice cube trays in the freezer also. Anyway, after emptying the ice tray for the maker, I set it in the sink to let the frost and ice chips melt. I looked at the tray to make sure it was clean, and found that the auger had some rust on the drive plate, that drives the clear plastic auger into the ice crusher/discard shut, has some rust on it. I don't know how long it has been rusty, but this could be what the bad taste the wife was getting, (didn't seem to bother me). I have searched the inter-web, but have not found a replacement, only some references to Dometic having discontinued the ice maker parts. I have disassembled the tray/auger, but the end of the auger has been pressed on, and dis-assembly it will surly break the plastic like parts.
Hear if the question. Is there anything I can coat the drive bar with, that will stop the rust, not chip or rub off, and is food safe? If I could get the drive plate out, I could plate it, but it seems that pressing it apart will ruin it. I know that there are people here that are more in the know about food safe coatings than I am.
Thanks for any help.
  • Passin Thru wrote:
    Replace it but you can't coat it.Probably needs galvanizing.
    I would love to replace the ice bin, but cannot find a source. The ice maker part is working well, and I can find a replacement for it. If I could get the rusted drive plate out, I could plate, but I cannot get the part out without destroying it. If you know of a source, I would really appreciate it.
