WAFlowers
Dec 29, 2017Explorer
First load the coach then have it weighed. At a minimum you want the axle weights. Ideally you want the corner weights (weight on each tire). Next go to the website for the make/model of your tire and lookup the pressure rating for that weight.
There is no single "correct" pressure. With the types of tires used on a Class A it is weight dependent.
Worst case use the max axle loading and pump them up accordingly. The ride will be harsh but you will not be under-inflated for your load.
38,769 PostsLatest Activity: Apr 03, 2026
