Executive45
Dec 29, 2017Explorer III
Ideally you want to know the four corner weights. That said, it's not convenient, not easy to locate someone/someplace to do that and just not practical. Alternatively just have each axle weighed and go from there. Most large truck stops, grain elevators, moving companies, even closed weigh stations if you're in Oregon or Washington have scales. Google's your friend - put in your zip and scales.
1. Load your rig as you would normally travel. Full fuel, 1/2 tank fresh water-less if that's normal for you, etc.
2. Go to the scale you've chosen. Pilot/Flying J charge $10.50 for weighing.
3. Pull up onto the scale making sure each axle is on a separate scale-they usually are broken into three scales. Front axle on one, rear axle on the second and the tag on the third.
4. Release your air brakes if so equipped.
5. Press the button and wait for the operator to tell you they have your weight.
6. Go inside and get your weigh slip.
7. Boot your computer and go HERE. Put in your tire size and that will tell you how much pressure should be in each tire. Remember, all tires on an axle should be set at the highest weight for that axle. In other words, you don't want 90# on one steer and 100# on the other.
As you can see, tire pressure is important and really pretty simple once you do it. Since we full time and our weight fluctuates as DW buys and gets rid of "stuff" we weigh our coach regularly. As we use Flying J for fueling, I will pull onto the scales about every fourth fill up or so and adjust my air pressure accordingly. YMMV....Dennis
38,769 PostsLatest Activity: Apr 03, 2026
