edm3rd
Dec 29, 2017Explorer
For the OP - Something no one has mentioned - tire pressure should be set COLD, meaning not driven and without the tires affected by sun. Determine needed pressure as mentioned by most of the above posts by weight. If you don't have a compressor at home, air up to tire sidewall maximum and drive home. Next morning, before sun heats the tires up, lower pressure to what you calculated by weight. It is not uncommon for sun/driving to cause a 10# or more pressure increase.
38,769 PostsLatest Activity: Apr 03, 2026
