supercub's avatar
supercub
Idling Diesel ??
I've read where it's not advisable to idle a motor home diesel engine for more then 5 minutes or so. I've talked to truckers that never shut off their engines except to change the oil.
Other then the obvious cubic inches and horsepower what's the difference in the engines between trucks and motor homes?
Thanks
  • Difference is Knowledge!
    A idling diesel will NOT come up to temp
    Idling a diesel causes unburned fuel to wash down piston cylinder walls
    Unburned fuel can get into turbo and/or crank case
    No GOOD reason to idle except to allow motor to cool down after a hard run....which would be 5 minutes or less
    Idling at start up is not necessary or worthwhile
    By the way.....
    Size....HP/Torque not much different either
  • If your engine has a DPF (Diesel Particulate Filter) extensive idling can be detrimental. I try to avoid it whenever possible.
    Pat in Menifee, CA
  • Idling for more than 5 minutes in a campground is kinda annoying. It hasn't got anything to do with your engine.
