pianotuna
Apr 02, 2014Nomad III
Hi,
Add up the wattage of everything you wish to use. Get a small psw unit. 300 watts will be fine
The fridge draws 325 watts--so if you wish to power it, too, get a 600 watt pure sine wave inverter.
A 300 watt inverter running flat out will draw about 30 amps. 600 will be double that amount.
With that small a battery bank I would not attempt to run the fridge unless you are trundling down the road.
38,769 PostsLatest Activity: Apr 03, 2026
