Crabbypatty
Apr 02, 2014Explorer
In my TT I found that both TV's and the two 110volt outlets in our bedroom are on one circuit in the shore power panel. I disconnected that and installed a standard three prong plug. I then installed a Xantrax 1200 watt inverter and plugged that circuit into it. So the two tvs sat dish and two outlets are always on the inverter and I have an on off switch. So when not in use i turn it off. This has worked perfectly for going on 8 years. My batteries I upgraded to two Trojan T 125's they are 6 volt tied them together to make 12 volts. This coupled with a charge wizard on the shore power charger continues to work perfectly going on 10 years.
38,769 PostsLatest Activity: Mar 31, 2026
