brianseay1's avatar
brianseay1
Ignition switch issue ?????
I have an 07 Coachmen Cross Country diesel pusher. I am sometimes having an issue when I go to start the engine it does nothing. I turn the key everything comes on like normal but the engine does not turn over. You can turn the switch off and back on and it will start or sometimes you do it a couple of times and then it starts. And then sometimes first turn and it fires right up. what does this sound like to y'all ? is it in the switch, loose connection somewhere or what ? It has me puzzled !!!
  • Have you checked your battery connections? First place I would look. Loose or corroded.
