Horizon170
May 27, 2014Explorer
You will never be happy until you raise the hitch ball AND raise the trailer frame.
W=front tire
X=rear tire
Y=hitch ball
Z=Trailer tire
They aren't equally spaced but kinda close in dimensions.
The distance that W raises (Entering drive, etc) then Y will lower almost the same. Look at the top picture and it should be obvious
what is needed.
You would be fine if the distance between X and Y was half the
present distance.
W=front tire
X=rear tire
Y=hitch ball
Z=Trailer tire
what is needed.
present distance.
38,707 PostsLatest Activity: Feb 18, 2025
