All_I_could_aff
Sep 29, 2017Explorer
I'm trying to help a friend with his 2000 Fleetwood F53 V10
A good friend of mine called me in a panic. He needs to drive his Fleetwood bounder F53 V10 Home from his seasonal site this weekend and is having some trouble.
It has a single 12 V chassis battery (65 series) and a pair of 6 volt battery's in series for the coach. The rig has been plugged in to a 30 amp circuit continuously for the last two years, and the batteries are all three or four years old, and have probably been boiled dry. As far as I can tell he has the original basic converter not a fancy modern one that would go into a low charging float mode.
The problem he is having is keeping the engine running. He was able to get it started while still plugged in to the 30 amp pedestal, but as soon as he unplugs from the pedestal, the engine stalls. By chance, the other vehicle he was down there in used a 65 series battery so I suggested he swap it into the RV chassis position.
It's still only starts while plugged into the pedestal and stalls as soon as you unplug it. Even if he had a bad alternator I would expect it to remain running an hour or two until the battery got right now. I am trying to guide him over the phone as best I can, otherwise I am driving down to help tomorrow afternoon.
Is there any reason That the bad coach batteries could prevent the rig from staying running? I suggested he try disconnecting the coach batteries based on the possibility that they were internally shorted and thus causing enough voltage drop to stall the Rig?
Any thoughts would be appreciated. This guy took me and for other friends on an all expenses paid trip to the Florida Keys two years ago in this very same rig. Thank you
