Dutch_12078
Feb 22, 2019Explorer III
garym114 wrote:
If I thought I needed it I would put a switch on the fuel pump 12v power line.
I haven't felt the need to use it, but a previous owner installed a matching switch in a blank spot on the existing dash switch panel that's just labeled "Accessory". Turning it off disables the fuel pump relay. I did test it though, and it does disable the coach quite effectively as expected.
