Community Alumni's avatar
Community Alumni
Not applicable
Feb 28, 2025
Jacking up class C motorhome
I had gathered from my ford e450 chassis manual that jacking points are located on axles, slightly beyond suspension and steering hardware.
Can you help clarifying how to jack to to change a tire or to shove boards under the wheel when stuck
The manual only mentions using a "provided jack" and just using that one jack throughout but its generic e450 manual not specific to motorhomes (RV manual just sneakily tells to call "roadside assistance" good luck with that where I camp), no jack was included.
I got 12 ton bottle jack and axle cradle adapter for it. My understanding if I use it I must then use jack stand(s) to support the weight right after I lifted it. Motorhome is about 13000 lbs GCWR.
To hold just one tire up for a short time - can I use just one 6 ton jack stand placed under the axle right next to bottle jack? Or, can I get away with two 3 ton jack stands instead? If I use two, do I just place them right next to each other under the end of the axle? My rear tires are duallies, basically I would have to climb under to place a jack. Wonder whats better. Then, shouldn't there be a way to find alternative frame jack points on the side, to lift without crawling under, at least for rear duallies?
  • I'm pretty sure when the manual is talking about jacking, they really mean to replace a tire.
    The problem with jacking the frame (assuming you find a structurally sufficient point) is you might lift 6inches and the tire stays in place as the springs extend. This is where the old jeep jacks were handy for off road but they had a bumper you could jack against.
    As far as jack stands, that's for longer term situations. If you are going to leave it up overnight, jack stands make sense. The time it takes you to crawl under and place the jack stands is going to be longer than shoving a board under and put you at more risk.
  • You’re really overthinking this. And my solid recommendation is stay on Terra firma with your lack of knowledge about extricating a stuck vehicle.
    simple answer is only jack up under axle or frame or possibly front a arms.
    And I’d not worry about a jack stand for a tire change. Much adoo about nothing.
    Loosen lugs, jack it up, replace tire, let it down, torque lugs. If this is considered risky to you then I’d suggest a roadside service subscription of your choice.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Moreover seems like the wrong type of camping rig if getting stuck off road is more than a fleeting concern limited to unintentional off roading.
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    Frankly I dont think I should be using jack stands, bottle jack should be supporting it for long enough to shove something under the tire. I dont see myself getting jack stands under the axle when its stuck low and needs a dig out to begin with. Unless I can a find jack point on the body and not on the axle like the manual says. I can pump the bottle jack without getting under even if its under the axlr if I use a pipe for handle extension.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      woh, now your talking about something different, this went from changing a tire to digging out when you are stuck.  two totally different situations, stuck, no I wouldn't put jack stands or even a bottle jack , its Infront of the tire and/or behind you have to dig, but if you are stuck enough the axel is buried then you have to get right under to dig, then yes you should be putting jack stands down.  changing a tire, I would put a jackstand under just to be safe while I am changing that tire.  I have seen bottle jacks pop out.
        Community Alumni
        Not applicable
        Its really the same situation. Not asking about digging out, been there done that. Assume everything is already dug out. Not really talking about buried to the axle case, just wheels buried a bit, this restricts under axle space. I definitely do not want to crawl under to place jack stands on this kind of soft and unstable ground while bottle jack is holding it all up. So my question boils down to alternative jacking points that do not require going under. As to using a bottle jack I dont see a harm as I can use handle extension to pump it without being under the RV. My questionis now if e450 got lift points other than axles.
  • what I would do is drive across a scale while fully loaded for camping and see what you front axel weighs and what your back axel weighs.  then find a jackstand set that rated for more than the highest axel.  I am assuming that your rear axel is well under 12000lbs haha so the 3 ton pair will work just fine.
    there are frame point you can use, but the problem is you have to jack it higher because the suspension will drop a bit.  so usually it is faster just to lift the axel.  one thing to not which ever you decide to go with put some squares of 3/4" plywood to put under the jack and jackstands incase you have to di it on a dirt road.
      Community Alumni
      Not applicable
      For sure. I carry some 2x6 pieces in the MH. Last time I needed it was on collapsing sandy soil that was easily turning into dust but called offroad recovery to pull me out.  When rear drive duallies are burying already, getting the jacks under the axle might be a no go that's why I wonder about frame points which are higher and can be accessed without crawling under, when your tail pipe is already close to touching the ground its easier to dig space outside on the edge.
      As to 2 3 ton jacks....is it more or less stable to use one 6 ton jack versus two 3 ton ones? I'd think having single point of failure with all weight on it is worse that having 2 jacks in play? And do I place them right next to each other under axle? (I wonder if this can stress the axle too much having one jack too far towards its middle, the official lift point is right next to the end)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
