- quinnmaflExplorer
I own a 2022 Newmar Bay Star. Less than 4000 miles. I have a Select-Trac (check engine light) that is intermittent. Had it to Ford twice. The first fix was a wiring connection (they said) It happened again so I took it back to Ford and they changed the throttle peddle and it happened again. I have read some threads on many sites that have a similar problem. One mentioned the NHTSA website has a software update...? Can anyone help?
- way2rollTrailblazer
While I am sure the information would have been helpful, this topic is 4 years old.
- ClydeNBonnieExplorerOne footnote. This Service Bulletin was issued in or around Nov 2020:
“SSM 49315 - 2020 F-53 Motorhome Chassis - Bent Or Damaged Rear Axle Tone Ring(s) With DTCs C0037 And/Or C0038 - 16,000-22,000 Lbs. GVW Vehicles
Some 2020 F-53 Motorhome Chassis 16,000-22,000 lbs. gross vehicle weight (GVW) vehicles may exhibit an anti-lock brake system (ABS) light on with diagnostic trouble code (DTC) C0037 and/or C0038. This may be due to a bent or damaged rear axle tone ring. Inspect the tone ring teeth on the affected rear wheel and replace the tone ring if damage is present. It is recommended to inspect the service tone ring before installation to make sure no damage has occurred in shipment. The tone ring is susceptible to damage during the ring to rotor installation as well as installing the hub and rotor assembly onto the axle housing. Use a suitable jack to aid in the installation of the assembly to prevent any contact with the tone ring during reassembly.” - ClydeNBonnieExplorerWe bought a new 2021 Newmar Bay Star w/ the Ford F53 chassis. Immediately ABS and traction control lights came on. Spent a month in Ford service department. Front left wheel speed sensor replaced. Did not fix problem. ECBM replaced. Did not fix problem. Wire harness overlay replaced. Did not fix problem. Left front tone ring assembly replaced. Fixed problem for 200 miles. Spent 12 days in another Ford Service Department. Wire harness overlay replaced again. So far, ABS and TCS lights have stayed off. Just spent 16 days in Ford service department for rear axle safety recall. At the suggestion of someone in another forum, we filled out a complaint form on the NHTSA website. I guess if enough people do, the NHTSA might investigate and a recall might result.
- quinnmaflExplorer
Hello, just wanted to reach out and see if you ever got the problem with your Bay Star (ABS/Traction control) figured out? I'm having a similar problem.
- willaldExplorer II
georgelesley wrote:
Already reports and pics on another rv forum of rear sway bar bracket bolts falling out on the “new” chassis, just like the previous F-53 ones did. You would think that after making vehicles for over 100 yrs Ford would figure out that spark plug wires and exhaust manifolds do not play together well and suspension parts sometimes vibrate and just might need locktite. Some things never change
Well, at least Ford still offers a gas Class A Motorhome chassis, and is trying to make it better with the new chassis they came out with. That is more than we can say for any other auto manufacturer right now.
Yep, first year a new chassis comes out, there will be the 'teething' problems like this no matter who the manufacturer is. I expect that, which is part of why I held off and didn't buy one the first year. - RedRollingRoadbExplorer
- willaldExplorer IIWe have put a deposit on, and are about to purchase a 2021 Newmar Bay Star with the new Ford chassis, engine. We will bring it home in a few weeks.
I spent an entire day looking over the new coach, crawling under it and looking around, test driving it, etc. Drove it for a good hour or so, total. I am nothing but impressed with the new chassis and engine.
Having owned a Georgetown 36' Class A (see signature) for 9 years built on a 2012 F53 V10 chassis...I'm here to tell you the new chassis handles noticeably better. Considerably less body roll in turns, and it overall just doesn't feel as much like a big, honkering RV as the old chassis did. It feels, rides more like a big car. Engine is noticeably quieter, too. When it does get loud, like when you get on the loud pedal hard, its a good kind of loud - A throaty, growling big block V8 kind of loud. I like it. :)
The V10 is a great, bullet-proof, rock solid motor that gave us years of great, reliable service. We worked it real hard, and it never had a single issue out of it all the years we owned it. However, it turns a lot of RPMs which make it kinda loud, and it ain't the cool kind of loud like this new V8.
I have read about the plug wire issues, know all about that. It seems from what I can tell, though, that this was/is a supplier issue that Ford had early on and has pretty well resolved now. I plan to have a very close look at the plug wires on ours when we get it, and if it doesn't look like the newer wire design, I'll go ahead and order a set of the newer wires (already found several places you can order them) and put them on. - georgelesleyExplorer IIAlready reports and pics on another rv forum of rear sway bar bracket bolts falling out on the “new” chassis, just like the previous F-53 ones did. You would think that after making vehicles for over 100 yrs Ford would figure out that spark plug wires and exhaust manifolds do not play together well and suspension parts sometimes vibrate and just might need locktite. Some things never change
- justinhscottExplorerWe have a 2021 Coachmen Mirada. We upgraded from a 2018 Thor ACE.
It’s no sports car but handles noticeably better - especially when a big rig blows by on the highway.
It’s generally quieter and much better at higher RPM.
MPG seems about the same, although I don’t really track it closely.
We’ve very happy with it. - dodge_guyExplorer II
Dale.Traveling wrote:
dodge guy wrote:
It will be nice to see if they will integrate all the electronics they said they would. Auto high beams, lane departure warning, blind spot monitoring, and so on.,,,
The problem you run into is the sensors need to be mount on the body then interface with the chassis systems. So,,, who provides, who installs and who warranties the systems? Considering the confusion regarding the lines of demarcation for simple things like the wipers, head and tail lights adding cameras, distant sensors, radar and such the level of frustration for the basic owner would get really ugly when the service centers, chassis and coach, tell them "Not my swim lane" the first time there's a problem.
I agree with you there. And knowing how the RV manuf assemble and install things, the sensors will probably be installed backwards, or behind metal shields and not work correctly! - Dale_TravelingExplorer II
38,782 PostsLatest Activity: Sep 10, 2026
