Effy
Aug 20, 2013Explorer II
The Sat dish/dome will feed a Sat receiver (directTV or dish). From the receiver you can only have one output. You can split them into 2 tv's but whatever is on the receiver is what you will get on all tv's downstream. Change the channel, they all change. If you have multiple TV's they may already be linked via switch box. in that case, feed the out from the reciever to the in on the switch box. It won't solve the problem of whatever is on the one receiver will be the same on all tv's downstream but it does provide the signal to all tv's. You may need a remote repeater in this case if your bedroom TV is out of line of sight from the receiver. If you want seperate channels on each tv, you will need seperate Sat receivers. I am not sure if one dome will feed multiple receivers. maybe someone else can answer that.
38,782 PostsLatest Activity: Aug 31, 2026
