dougrainer
Aug 20, 2013Nomad
You need to Contac Jayco. The Precept is a brand new model for 2014 and who knows how Jayco wired the TV's. We have 2 on the lot and have not sold them yet, so it is difficult to determine what Jayco did. Doug
I called Jayco and typical Jayco, they have NO CLUE. I looked at our 31UL. You should have the 2 40 inch TV's and the small LCD in the bedroom. I see NO extra cables (video/HDMI/Component/Coax) at all. the ONLY TV that you can easily hook up is the bedroom TV and run your own cable. It seems the dash DVD system supplies Video for all 3 TV's. I have NOT verified that. The Video for the Bedroom is the Standard Yellow(video) and Red and White Audio. I assume that the 40 inch TV's are supplied the same. They are not using HDMI or Component cables for the Dash DVD player. I have requested a Schematic for this 31UL unit to see. The Schematic they sent me 30 minutes ago is the generic dash DVD/2 TV wire schematic. It does not show the roof top prewire and the 3rd TV. If you do not care about resolution, you can connect all 3 TV's to the coax rewiring the TV booster coax in the bedroom. IF you do not care about HD reception on the sat system, then you will have no problem by rewiring the Coax at the bedroom TV area. You will just have to have a NON HD Sat receiver. MOST HD sat receivers do not have a Coax output. Some older HD Sat receivers had a Coax output.
38,782 PostsLatest Activity: Aug 31, 2026
