Bill_Satellite
Jul 04, 2014Explorer II
Most wiring in an RV is going to be coax and that eliminates the use of HD via satellite as you can only send the SD version via coax. However, in this case, since the dome can't receive any of the DirecTV HD programming anyway, you use a DirecTV SD receiver like a D12 and connect the coax to the same switch box currently used to switch between OTA, Cable, DVR, etc.
38,783 PostsLatest Activity: Sep 22, 2026
