Geocritter's avatar
Geocritter
Inconsiderate engineering
If any of y’all heard any far off cursing and swearing a week ago it was probably from me and a friend removing the grey water tank from my Class A RV. It seems that in a classic case of “inconsiderate engineering” Holiday Rambler had apparently chosen to build the RV around the grey water tank. I finally had to remove the badly cracked grey water tank by cutting it into two sections. I’m now having a slightly smaller grey water tank fabricated that I can reinstall in one piece.
Stories such as mine are far from uncommon. I really get upset when it’s something that's a “wear” item that the engineers know for certain will need to eventually be replaced (out of warranty of course). Car engines that must be removed to replace spark plugs, how about those AC condenser’s that are so buried in the dash so that a simple replacement turns into a day long ordeal just to remove the old condenser. I once made the mistake, on a Goldwing website, of criticizing Honda’s use of interference fit valves on a touring bike engine. You’d think I’d criticized God or something, yet I still wonder why they’d build an engine that could suffer extensive damage and expensive repairs should a timing belt break. In my opinion, since it’s a touring bike engine where reliability and maintenance ease should be first and foremost, interference fit valves have no place on such an engine. But what do I know; I’m but a simple geologist.
Anyone care to post or vent about inconsiderate engineering they’ve run into over the years.
Steve
