zb39
Feb 09, 2019Explorer
Induction cooktop
Does an induction cooktop run off of the inverter or is it genset only if not plugged in. I am referring to a cooktop in a large DP. Tiffin, Newmar, or Berkshire. thanks
Ivylog wrote:WOW! Thanks for the update. Our inverter pulled 3 amps at idle, and like you, we like to boondock in the spring, summer, and fall, so I disconnected it and changed the wiring.
Positive...amps went from 10 to 7 when I unplugged it. Checked it two times.
You do not need induction cookware...anytime magnetic will work including most SS pots and pans.
