wolfe10
Jul 24, 2014Explorer
Contact info for Roger Haag (old used bear): [email protected]
One issue that can lead to inability to bleed the PS system is an autopark brake that is out of adjustment. Too much slack/clearance between brake shoes and brake drum can require the use of so much fluid to release the brake that you drain the PS reservoir of fluid. So air is re-introduced to the system.
38,782 PostsLatest Activity: Sep 10, 2026
