Dutchstar02
Oct 17, 2015Explorer
The thermistor turns off the fridge when it gets cold. If it never shuts off then the defrost cycle won't work and you get a buildup of ice on the fins in the fridge. To check the thermistor have the fridge running on propane. Put the end of the thermistor in a glass of ice water. If it's working properly, it will shut off the gas supply. It's easier to test on propane because you can't tell if it's off when it's running on electric. If the thermistor is working then it's likely a circuit board.
38,782 PostsLatest Activity: Sep 10, 2026
