jhilley
Sep 13, 2013Explorer
Coyote74 wrote:
Make sure your not hooked to a ground fault interupter socket. It won,t support the amps of heater.
They definitely will. They typically are 15 amp, which will support the 12.5 amps the heater uses. 20 amp are also available.
If it is a 15 amp breaker tripping, OP may have something else on the same circuit.
38,778 PostsLatest Activity: Jun 10, 2026
