rgatijnet1 wrote:
There are the coax cables AND the control cable that supplies power to the antenna.
Right. There are 3 sat cables (labeled "A", "B", and "C") + 1 control box cable.
Currently Winegard provides two RG6 cables.
Do yourself a favor and run 3 RG6 cables into the RV for possible future upgrades.Bill.Satellite wrote:
JimM68 wrote:
Does anyone know for sure if the trav'ler will support a dish hopper?
Does the required "solo node" switch mount outside or inside?
The Dish Trav'ler (SK-1000) does support the Hopper and Joey combination. You can install the Solo Node either inside or out. Just base it's location upon where you will be running your cables that leave the Solo Node.
I would NOT suggest placing a Solo (or Duo) Node on the roof because it limits
future upgrades.What future upgrades?
A Winegard Traveler can support
two Hoppers using a Duo Node that is connected to the 3 sat outputs (A, B, and C).
While you might not plan on installing two Hoppers, running those 3 cables inside your RV gives you that option.
