I remember a similar problem when doing the steering damper. Jacking up the corner of the vehicle is the solution, and it's not too hard. Note that this doesn't mean jacking up with the usual jack points for changing a tire, since those are on the I beams for the axles and lifting them doesn't appreciably change the position of the suspension components relative to each other; instead, jack the frame, the solid part of the axle assembly, or something similarly beefy and independent of the suspension.
Changing the front shocks is not a lot of fun, but it's certainly not at all impossible for a DYIer...it's mainly just that there is not great access to the top mounts for wrenching on things. (Paying for any parts is never fun, it goes without saying!)
