Biggyniner
Feb 19, 2017Explorer
fourthclassC wrote:
Interesting situation as I am considering a new roof AC also. Do you know if your Winnie has a square tube aluminium frame? If so it may only be a bending from the weight and bumps over time and may not need any attention or addtional support. If it has the aluminium frame it may just have bent and then stabilized within the structure. I hope it is that. Agree with the comment about Marine Tex. It is great matereial. Might be good for shimming to straighten out the frame if needed.
It does have the aluminum framing. I did find it interesting that they did use some wood around the a/c vent. I will check out the Marine Tex stuff if it starts leaking, so far the rain has not come in.
38,766 PostsLatest Activity: Jan 10, 2026
