warrenjo46
Sep 13, 2020Explorer
EV2 wrote:
One consideration when plugging the shore power cord into the inverter is to turn off the 110 breaker for the converter/charger. If this is not done, the converter will attempt to charge the batteries that supply the inverter. This loop will either use excessive energy at a minimum or trip the inverter. We have labeled our 110 breakers for the converter charger and air conditioning and turn them off whenever plugging into the inverter. Works perfectly. Also may wish to avoid using the microwave.
(Highly recommend a pure sine wave inverter when doing this.)
Yes I did purchase a pure sine wave inverter (2500W).
I will install a normally closed relay in the power to the converter that will be energized to open when the inverter is turned on. That will prevent the converter from trying to charge the batteries with power drawn from the batteries.
My only problem with this plan is "where is the converter?"
After looking at several wiring diagrams and schematics I discovered that the converter is located under the refrigerator behind the grill that looks like the cold air return for the furnace. Since motorhomes are very compact manufacturers need to tuck devices into unexpected places.
