tropical36
Oct 22, 2020Explorer II
newizu wrote:
This question is for Tropical36. I am interested in doing what you described you have done to connect inverter as shore power. Would it help if I were to disconnect power bank from main setup and use it as a stand-alone power bank to power the inverter?
Not really understanding the question here.
What are you referring to as the ....power bank... and are you perhaps talking about your house batteries?
What do you mean by the main setup?
All I was saying is that you might just plug your shore power cord into the inverter's 120vac output when you want to use it. Again, you must first open every non essential circuit breaker, when doing so or risk depleting your house batteries in short order. As for what you can keep, it will depend on the size of the inverter.
If you only want to operate a couple of things and the inverter is only 1000watts or less, it's not all that hard to run a couple of dedicated outlets here and there, like I did in our old gas coach and be done with it, as another option.
