time2roll
Oct 23, 2020Nomad
MAIN-needs to be on
AC-best to have this off
MICRO & W/H is interesting. Must have a load shed device. OK to be off but if you want to use the M/W it is best to set the W/H to propane only.
GFCI-generally you will want this on.
RECEPTS-yes you want this on too.
CONVERTER-off
The only question is where does the fridge get 120v power. Need to switch fridge to propane only unless by luck it is on the converter branch circuit.
Once you have a road map you may want to print it so if a non technical person wants to use the inverter the sequence is very simple.
CONVERTER-off
