rlb8s's avatar
rlb8s
Installing back up camera...
I want to install a wireless back-up camera on my 2013 Tioga Montara 25K. The installation seems fairly straight forward, but I thought I'd reach out to the board members for any advice from those who have installed one themselves before I put a hole in my exterior walls. Any issues w/ screwing into the exterior wall? What is the best method to ensure that water doesn't enter the wall through the screw holes? Thanks.
  • Dastagg - any issues mounting it? Screwing into the exterior has me a little nervous.
  • Dastagg wrote:
    I bought this as well as a second camera. Not wireless, however, I know it works since it is wired. I love it. When in reverse, it goes to the camera pointing lowand other gears, it points at the higher installed camera pointing as a rear view camera. Wife and I love it. Thinking about a third camera for front bumper for close looking at front, such as tight spaces.
    Rear View Safety 7" LCD Color Backup Camera System with Audio
    http://amzn.com/B002GM5GKO
    I am looking for a rear view camera. What brand did you get
  • I bought this as well as a second camera. Not wireless, however, I know it works since it is wired. I love it. When in reverse, it goes to the camera pointing lowand other gears, it points at the higher installed camera pointing as a rear view camera. Wife and I love it. Thinking about a third camera for front bumper for close looking at front, such as tight spaces.
  • Joe - No back window. I have one on the back door of my truck camper and I like it. Not an option on the class C.
  • Before you spend that kind of money, buy a
    Fresnel Lens. Stick it on the inside of the back window. It gives you a wide angle view of what's behind you. I have one that serves the purpose. Wish I'd done that before I bought a wired camera and monitor that cost big bucks. I never turn it on now. For $15, its worth a try.
  • Before you go and do any drilling and cutting, be sure that the camera works for your vehicle.
    There was some talk awhile back, about how the cameras were designed for pick-up trucks and vans, and didn't have a strong enough signal to transmit from the rear of a large MH. You know, great for hooking up a trailer, but not for seeing out the back of a 35-40' motorhome.
    I'd give it a try with some adapter cables or whatever you need, to put the camera at the back of the MH, and the monitor screen up front where you would use it.
    Better to find this out now, rather than later on, after drilling holes!
    Now, if the camera you have is made for the RVs, then you should be fine, but I'd still want to check it out first!
    If you screw into the wall, just make sure to seal it well (silicone).
    I think I remember one person putting their camera right under the top rear running light, and he was able to tie the power cable into the light's wiring. Yes, he had to turn on the lights when he wanted to use the camera, but it was a fairly quick and easy installation.
    Good luck:)
