opnspaces
Apr 01, 2023Navigator III
Dried poop is only like concrete when it is dry. If you put it in water it will re-hydrate. The issue is when people try to conserve water by using only a tiny amount of water to flush. Or they leave the black drain valve open and try to use like a residential toilet.
Short answer, don't do the two things above and you will be fine no matter where you put the hole in the tank.
38,782 PostsLatest Activity: Sep 10, 2026
