ets1996
May 27, 2015Explorer
Look around the firewall under the hood on drivers side you might find an exsisting wire or cable penetration with enough room to pass the breakaway switch wire plug thru. If not you may have to drill a new hole just be careful where you drill as not to hit something, fuse block, relays, etc on the inside. The local parts store has an assortment of different size gromets for these holes. also some electrical tape and silicone where wire passes thru can help prevent chaffing and shorting out. Hope this helps Good Luck
38,780 PostsLatest Activity: Aug 05, 2026
