Sandia_Man
Jul 29, 2015Explorer II
Onan generators are very reliable if properly maintained and are what most RV manufacturers install in their rigs. If the RV is factory prepped for a generator, installation is relatively easy as long as you use the proper type of Onan generator as they do have different methods of dispersing exhaust. A 4000 watt Onan is normally installed for a single AC rig , or a 5500 watt Onan for a rig with 2 AC units.
Also which fuel type will be used, propane, Diesel, or gasoline? Portable generators are not designed to run in the confined space of the generator compartment but they can be stored there and removed for use once you get to your campsite. Portable generators are a popular choice for many as they don't need much power and don't want to overspend on an item they may only use sporadically throughout the year.
A 2000 watt portable generator will run most items including microwave but no AC. A 3000 watt portable generator will run most single AC units, you can parallel two 2000 watt portables for 4000 watts, capable of powering your entire rig. Honda, Yamaha, and Champion inverter generators in the sizes above are popular choices here on the forum and all have a good reputation for customer service.
