j-d
Jul 30, 2015Explorer II
Typically Onan 4000 in a C or 30A Class A. I've seen Onan 2800 but only in truck campers. Get the mounting dimensions and verify that 4000 will fit the space. I added an older Onan, the "4.0 RV Genset" to an older coach that was also pre-wired and it went pretty well.
I, personally, haven't looked at our RV gas tank to see how the genset fuel tap looks or connects. If the coach is new enough to be fuel injected, you can't tap into a fuel supply or return line near the genset. Must run fuel line from the tank.
