senf
Sep 03, 2014Explorer
Interesting! My two batteries are reversed to yours. The optional battery being behind the rear wheel. Both batteries are seated in metal trays. The metal trays are attached to slides which are also attached to the sides of the compartment. The battery weight is distributed across the metal tray and then onto the slides and the sides of the compartment. If the optional battery is installed at delivery, I very much doubt that any reinforcement would be needed, however, there would be something to enable the battery to be held rigidly in place - such as a tray.
Roadtrek Service will no doubt have an answer.
Connecting two 12 volt batteries together requires parallel connections - positive to positive, negative to negative. Use the same cable thickness or gauge as the existing battery.
38,766 PostsLatest Activity: Jan 10, 2026
