dougrainer
Dec 18, 2013Nomad
As someone who has removed the skin and have fixed rotted slide rooms, IF the OEM did not install a window, then it is not wise to try and cut a hole and install a new window. The strutural integrity of slide rooms is all based on as little weight as possible. So, they do not install standard aluminum or wood studs like in a regular wall in the RV. The odds are, if you decided to cut a hole, you may end up cutting one of the few wood/aluminum studs that give the slide out wall box its strength. Doug
38,776 PostsLatest Activity: May 15, 2026
