Dale_Traveling
Dec 18, 2013Explorer II
I think is doable. I would try and keep the window size to no more than 1/2 the total depth of the slide. The big unknown is if there are aluminum studs in the slide wall. Not even sure how to check considering a stud finder senses the steel nails in the stud. Easy enough to cut thru the slide wall with either a saber saw or saws-all but once you start cutting there's no turning back. :E
Personally I wouldn't do it. Risk is too high for the gain.
38,776 PostsLatest Activity: May 14, 2026
